IH 364 diesel capacity - help if you have access t
Greg
04-20-2004 16:54:20
I have an IH 364 diesel - just bought it and don't yet have a manual. If you do can you tell me:
1) what type fluid to use in the trans/diff
2) how much it holds
NC Rick
04-21-2004 16:50:49
 Re: IH 364 diesel capacity - help if you have acce in reply to Greg, 04-20-2004 16:54:20
Greg,
There should be a drain plug directly under the PTO shaft, at least there is on the B-275. This area usually gets covered with crud so it may be hard to see. I use the Traveler brand 80W-90 oil from TSC in the transmission/differential. I know its not a premium brand but it's probably better than anything that was available when the tractor was new in 1959.
I also use the Traveler Universal Hydraulic Fluid in the hydraulic system. It is 20 weight non-detergent oil which is exactly what the manual requires.
Rick
Greg
04-21-2004 19:44:35
 Re: Re: IH 364 diesel capacity - help if you have in reply to NC Rick, 04-21-2004 16:50:49
Thanks for your help. I didn't think to look in the very rear for the drain plug. I was under the tractor and never saw anything like it. Glad I asked this forum. Did your B275 hold about 6 gallons in the rear/diff as someone here suggests? Approx. how much did the hydraulic system hold?
parts man
04-20-2004 19:00:43
Greg, it should take 80-90 gear oil, about 6 gallons. There is a level plug on the side of the transmission case under one of the foot boards, the left I think.
Greg
04-21-2004 06:30:40
 Re: Re: IH 364 diesel capacity - help if you have in reply to parts man, 04-20-2004 19:00:43
Thanks parts man. I found the level plug, it is just where you describe. The fill plug is up right by the shifter. I only find 2 drain plugs and they are close together (about 8-10" apart) right below the area of the shifters. It bothers me that the rear differential housing is lower than either of these 2 drain plugs and I can't find any other drain plug for it. I looked real good, even looked to see if it was hidden by my drawbar but I just don't find one. Surely there is a way to completely drain the diff isn't there? I don't have a GSS1442 Chassis Manual for this 364 yet but I sure would like to know how to drain that diff all the way. You have any ideas or know someone who has the manual that could tell me?
lee
04-21-2004 17:53:07
 Re: Re: Re: IH 364 diesel capacity - help if you h in reply to Greg, 04-21-2004 06:30:40
The plug is at the rear of the diff house way down low at center below the PTO output.
parts man
04-21-2004 18:08:29
 Re: Re: Re: Re: IH 364 diesel capacity - help if y in reply to lee, 04-21-2004 17:53:07
Like LEE and Rick said, the drain is under the PTO shaft, just above the swinging drawbar. It is horizontal and hides easily. Make sure you pull all 3 plugs as they will have water in the case from condensation.
Greg
04-21-2004 19:47:34
 Re: Re: Re: Re: Re: IH 364 diesel capacity - help in reply to parts man, 04-21-2004 18:08:29
Thanks partsman and lee, I am not looking at the tractor right now but I'm sure I'll be able to locate that rear drain plug with your description. I bet there will be some ugly crud come out when it's drained. I checked it at the level plug this past weekend and it's not low or too full but I sure will feel better draining it and installing new fluid. Thanks again for your help.
