3444 gas backhoe
Billy ar
04-21-2004 08:19:57
Where do you find a carberator kit for a 3444 IH backhoe? Local auto parts no luck. # on the brass tag 938 3228 Zenith
JLE
04-23-2004 01:07:48
 Re: 3444 gas backhoe in reply to Billy ar, 04-21-2004 08:19:57
I know of an after market carb. that works real well. If intrested e-mail me. Jim
aaron
04-21-2004 08:27:57
When you can't find parts at the auto store, just break down and head into the CaseIH dealership, they will have it for sure. I know it is a simple response but you did not say you tried them yet.
ken
04-21-2004 12:43:29
 Re: Re: 3444 gas backhoe in reply to aaron, 04-21-2004 08:27:57
well aaron if i remember correctly you have to buy each piece individually such as float,needle,seat gasket, etc,but i don't think they are availible anymore and i'll say this probably won't help your problem,there is a guy out in ohio thAT REBUILDS THEM WITH NEW FLOAT bowls that is the part that takes a s#*t,look at spending about 350.00 to 400.00 what i did was use a willys cj2a carb bolts right up and works beatuifully.the only drawback is you have to notch the hood for the hose from the carb to the aircleaner.
Billy ar
04-22-2004 17:43:17
 Re: Re: Re: 3444 gas backhoe in reply to ken, 04-21-2004 12:43:29
Ken thanks for the info I knew something else would work.
