no $ for new rings, should I hone cylinder anyway
aaron
04-21-2004 08:22:49
Would just a light honing to the cylinders be foolish if I were to put the old rings back in? The rings look alright, the tractor sat for about 15 years causing the sleeves to get some minor flash rust on them, just a bit. Would like advice as I don't want to hone only to lose compression! I had the head rebuilt and have new the new head gasket so the top should be good for holding compression, just don't want to cause excess blow by through the rings. Thanks,
Aaron
colekicker
04-21-2004 18:08:18
 Re: no $ for new rings, should I hone cylinder an in reply to aaron, 04-21-2004 08:22:49
How bad is the rust? I had some pretty harsh rust on my SM and we used a round wire brush on a drill. Didn't hone. Put the pistons and old rings back in. No blow by and runs like a spotted ape down the pull track.
49 Cubber!
04-21-2004 17:11:05
I did that once on an old M and got away with,but on my 14 it didnt work. It had to sit for a couple more years.
Nebraska Cowman
04-21-2004 08:34:18
A light honing to break the glaze would be a good idea but sure as the world someone will dissagree with us. I put lots of used rings back in.
Dave_Id
04-21-2004 09:14:57
 Re: Re: no $ for new rings, should I hone cylinde in reply to Nebraska Cowman, 04-21-2004 08:34:18
I agree, count at least one person that agrees with you.
steveormary
04-21-2004 16:07:05
 Re: Re: Re: no $ for new rings, should I hone cyl in reply to Dave_Id, 04-21-2004 09:14:57
arron;
I have done that a time or two,honed the cylinders and put the old rings back in.Never had a problem.
steve
