Order Farmall Cub Parts Online
cub coil 6-12 volt
chad
04-21-2004 12:03:38
my coil died after five or six years of use. i took the bad one off and went to the local part store. i told him it was a 6 v cub. he told me (and showed me) that it is a 12v coil. he said there had to be some kind of inline resister going to the distributer. i dont have one. so i took the new 6v coil he had and it works fine. what happened, what am i missing, why will both coils work on a 6v system ?
Rudi
04-21-2004 13:33:33
 Re: cub coil 6-12 volt in reply to chad, 04-21-2004 12:03:38
third party image
Chad:
Phil answered quite succinctly. Most Cubs are 6v. As for coils a good universal external replacement is from Napa or any of the other auto parts stores - UC12 is the model number.
If you want to learn more about your Cub, check out the link below.
Phil Auten (TX)
04-21-2004 12:16:24
Eiter coil will work, but the 12V coil won't put out as hot a spark as the 6V one will if used on a 6V system. Since the older Cubs were 6V, there would be no resistor in series with the coil primary side.
Phil
chad
04-21-2004 14:01:14
 Re: Re: cub coil 6-12 volt in reply to Phil Auten (TX), 04-21-2004 12:16:24
thanks phil, i was scratching my head trying to figure out why that 12v didnt burn out my points or something else. chad
