Impulse coupling weights
Jeff
04-21-2004 20:11:42
does the coil in the small steel spring that goes under the impulse coupling weights go around the post that the weights rotate on or does the coil go out in front of the post. when i took them off i swore that they were out in front but when i put them back together it seemed to make more sense that the coil loop around the post. thanks
jeff
Sid
04-22-2004 03:03:35
 Re: Impulse coupling weights in reply to Jeff, 04-21-2004 20:11:42
Have just checked a spare coupling. You were correct in your original observation, the coil goes to the front of the post.
