switching a 400 to LP
hal
04-22-2004 14:21:38
Has anyone had experience on switching a 400 to run on LP. I plan on using it to rake hay and pull wagons around, not heavy pulling. Can you switch just the carborator only or do you need to change the manifold as well. How well will they run on LP with the gasoline head and pistons? Thanks Hal
Nebraska Cowman
04-22-2004 15:30:45
 Re: switching a 400 to LP in reply to hal, 04-22-2004 14:21:38
you will loose a little horsepower but lots of them are done that way. You don't even have to change the carburetor, just tap a line into the bottom. i have no idea what kind of an orfice they use.
