More 450 Questions
Harlen Larson
04-22-2004 19:17:10
Just getting used to the 450, only had it two weeks. The steering is real sloppy right in the steering box above the motor. Can I do anything with this? It is bad enough where I don't think I would want to use road gear. Also I notice the tractor runs fairly good cold, but after running about ten minutes it starts to cough and die, from the time it starts doing it, it will kill in a couple of minutes. The plugs,wires,cap and even the coil appear to be fairly new. Have not taken the cap off. The sediment bowl also seems clean. Any ideas? Thanks, Harlen
Dubl J
04-25-2004 13:18:58
 Re: More 450 Questions in reply to Harlen Larson, 04-22-2004 19:17:10
Harlen, The steering box is a common problen in the older farmall's. Our 300 almost shook you off the seat while going down the road. What we did was a complete overhaul. Case IH makes new bushings that go inside the main shaft tube, which we replaced, we also took the shaft to a local machine shop to build it up a couple thousand's since it showed signs of wear. Put it all back together with new seals... now it drives great and even holds oil. Dubl J
Bill Evans
04-23-2004 04:32:42
Be sure you have good fuel flow to the carb. It might be trickling in at a rate slower than the engine consumes it. Eventually, the bowl will empty and cause the coughing.
