Tinkering with my 400
Kelly C
04-24-2004 12:00:19
third party image
Finnaly got a bracket made for the depth control. Found a used bracket but $75 is way too much for me. WOrks good so will see how long it last. Also rigged up a bale spear for the fast hitch. Picked this one up for $100 on auction. Had to weld the top link bracket on as this one was made for a loader.
Wardner
04-24-2004 12:55:58
 Re: Tinkering with my 400 in reply to Kelly C, 04-24-2004 12:00:19
Good luck with the bracket. It looks like you got the right cylinder anyway. Even with the stock bracket, you will find that the cylinder will stall under full pressure sometimes. This is why I would only use the IH mfg-ed item.
I suggest that you put right angle adaptors on the ports. With your bracket you could even rotate the cylinder 180* so that the ports are tucked inside.
The new cylinder and bracket will make a big difference with the bale spear. You should get an additional 8-12" lift at the point plus fork-lift type tilt.
Kelly C
04-24-2004 17:03:41
 Re: Re: Tinkering with my 400 in reply to Wardner, 04-24-2004 12:55:58
Yea I will do a few things with the cylinder. This was just me sticking it together to see if it works.
