Farmall Question?
Randy
04-24-2004 17:57:46
Hello, And thank you for your help.
I'm working on a old or older Farmall Model M
tractor. But it has a blade on it and the nose comes out from the grill. I know its a Model M
But has anybody seen one like this?
Someone said it could be a 1930 to 1940's
Big gap, But it would help with the right year.
Runs, But needs the whole wiring redone.
And looking for diagrams. Anybody help!
Thanks and have a great day.
Wayne Swenson
04-24-2004 18:12:12
 Re: Farmall Question? in reply to Randy, 04-24-2004 17:57:46
Look in the "tractor photos" area to the left of this page for images of an M.
Look under "articles" for wiring diagrams.
Compare your serial number with the listing under "serial numbers".
Serial number is located on the left side of the clutch housing; if it is missing, the motor serial # will be a close match. It is located behind the generator on a flat surface on the engine block about 1" X 3" in size.
Let your fingers do the walking!
Good luck.
Nebraska Cowman
04-24-2004 18:11:48
no idea randy. The first m was built in 1939. Blade? Where? Under the belly like a patrol?
