Compare Super c with Normal C
Faber McMullen
04-25-2004 03:57:30
Dear Folks:
I recently purchased an old tractor with the remains of original decals that just had a small "C" that goes on the side tinwork. THe serial number was 166677. I could not find it on the "C" serial numbers. Could it be a "Super C". If so, how was that different from the earlier C models? And, was there no different markings for the Super C?
Paul Shuler
04-25-2004 13:08:29
 Re: Compare Super c with Normal C in reply to Faber McMullen, 04-25-2004 03:57:30
Here is a side by side photo
BillWV
04-25-2004 10:01:42
The Super C serial numbers were 6 digit (1xx,xxx), the plain C's were 5 digits. The Super C did have specific decals...people seem to use them interchangeably. Probably half or more of the "Super C"'s I see advertised are actually C's with SC decals. But then the Super C that I bought was advertised as a C.
The Super C had a bigger engine (123 cu. in. vs. the 113 in the C). The curved pedals and lower crank hole in the grill are the easiest visual cues to identifying a Super C. There were supposedly many other improvements in the castings that increased weight and improved strength. None visible that I'm aware of.
Good luck,
Bill
Ty
04-25-2004 08:35:23
Way back in the day when my dad was a kid his dad had a c. The neighbor had a super c. Dad always had to go over and help put up hay. He said that you can tell a differance in power between the 2. The super c had more power and better equiped like the other posts say.
Farmall Ed
04-25-2004 06:06:47
According to the letter series book by Guy Fay, that serial number would be for a 1953 Super C. I work on a friends Super C some,it does have hydraulics and a two point hitch,never worked on a regular C so I dont know what all the differences may be,someone on this board will know. Ed
Randy in NE
04-25-2004 06:28:27
 Re: Re: Compare Super c with Normal C in reply to Farmall Ed, 04-25-2004 06:06:47
The Super C will have disk brakes while the C will have band brakes. The brake pedals on the Super C are curved where the C's are straighter. The C has very little clearance between the gas tank and the hydraulic unit while the Super C will have about an inch or two of space. The Super C has a taller radiator so the grill is slightly different. Take a look in the Tractor Photos to the left of this page. The lower part of the grill down by the hole for the hand crank is distinctively different between them.
