560 spark plug oil seepage
joe
04-25-2004 08:17:32
just overhauled my 560 gas (about 6 hours on it)head was rebuilt and the number 6 spark pulg has oil coming out around it. several other plugs have a trace. new plugs. removed and reinstalled. still the oil leak. any suggestions???
Bob
04-25-2004 09:28:51
 Re: 560 spark plug oil seepage in reply to joe, 04-25-2004 08:17:32
For one reason or another, your spark plug is not tight enough, or the gasket area of the plug or head is damaged, and combustion products are "weeping" out, and showing up as an oily substance.
No matter what condition your engine is in, if the plug is properly sealed to the head, there will be no leakage at the sparkplug.
WOW
04-25-2004 09:12:07
Does it miss or will it run ok?? How much oil has it used?? Sounds like poor valve guides or the little rubber seals around the valve stems were not put on correctly.
If it was mine I would pull the dickens out of it for a few hours and see if it dries up and watch the oil level
joe
04-25-2004 09:33:36
 Re: Re: 560 spark plug oil seepage in reply to WOW, 04-25-2004 09:12:07
runs fine. no miss. new guides / seals. new seats and valves upgraded for unleaded gas. $400.00. will try new spark plugs again. it does not seem to use oil. rings seem to have seated ok. probably needs more hours for complete break in. thanks.
john
04-25-2004 16:45:03
 Re: Re: Re: 560 spark plug oil seepage in reply to joe, 04-25-2004 09:33:36
i have the same problem with my 656 gas,even on the same plug.. working the tractor doesnt seem to help any but it never fouls out..
