1566 3 point hitch
Jim
04-25-2004 15:30:04
I have a problem withthe 3 point hitch falling down when the tractor is shut off, as soon as I start it it will come back up. Also I have noticed that if I hit one of the remotes the hitch will come up a little. Was wondering what to check on this as I want to get fixed before painting the tractor.
Aces
04-26-2004 05:04:08
 Re: 1566 3 point hitch in reply to Jim, 04-25-2004 15:30:04
Jim If the hitch is going down with engine off I would say you have a leak under the deck some place. Could be the cushion relief valve o ring on the control valve or bad cylinder seal. You could put some weight on it with engine off and look in the back through the 3 piont link hole for oil driping, or there is a little plate under the seat from the front about 2" x 3" with 1/4" screws holding it on that should let you see the cushion relief.
