IH 30 loader ?
sheep farmer
04-25-2004 18:29:00
What is an IH 30 loader worth in Iowa. My has double acting cylinders, is this original?
rustyfarmall
04-25-2004 18:46:20
 Re: IH 30 loader ? in reply to sheep farmer, 04-25-2004 18:29:00
If it is in excellent condition it might be worth $200, but don't bet on it. The original cylinders did appear to be double acting cylinders, but were not. They are single acting, the front of the cylinder is used as a reservoir for the hydraulic oil because the belly pump on the tractor did not hold enough oil to lift the loader all the way to the top. If you will notice, the hoses coming from the front of the cylinders are plumbed into the fill pipe on the belly pump.
