1466 3-point lever
SGT K
04-26-2004 10:00:17
My 1466 three point hitch drops unless you hold the lever up. If you tie the lever in the up position it stays up, even after you shut the engine off. Is there an easy adjustment for this? It seams like there used to be a little resistance to moving the lever, but now it moves realy easy and won't stay in one position.
Paul
Chuck's Repair
04-26-2004 15:39:30
 Re: 1466 3-point lever in reply to SGT K, 04-26-2004 10:00:17
There is a clamp around the shaft at the bottom of the lever with a 5/16 capscrew that can be tightened.An easy fix but don't overtighten it or the implement will chatter while you are lowering it.
SGT K
04-27-2004 05:39:25
 Re: Re: 1466 3-point lever in reply to Chuck's Repair, 04-26-2004 15:39:30
Thanks Chuck, I'll look at that tonight.
Paul
