Another Farmall A rear weight question
Kevin (FL)
04-26-2004 13:06:04
Will the rear A weights also fit a 140? And another question--is there anything unique about the mounting bolts on the A's & Cubs? I have a set of weights to mount on our Cub, but there were no bolts that came with the weights We're also getting a set for the 140 (if the A weights are the same) and those don't have bolts either.
Jim Becker
04-26-2004 19:29:19
 Re: Another Farmall A rear weight question in reply to Kevin (FL), 04-26-2004 13:06:04
The rear weights for an A should fit a 140. Cub weights are held with a different size bolts than the A weights.
Kevin (FL)
04-27-2004 14:24:14
 Re: Re: Another Farmall A rear weight question in reply to Jim Becker, 04-26-2004 19:29:19
Thanks Jim. I can get a set for $50 but didn't know if that was a good deal or not and whether they would fit our 140. These are for an A model.
