Re: Re: Radiator off M with WFE
r4etired
04-26-2004 18:54:09
adding to Jon' comments If you have an early M there is not a hole in the casting to get a socket on the nuts.If your lucky you can compress the springs by prying up the radiator then hacksaw the 7/16 bolts. Leave a long enough stub to weld on new threads.
Dick Davis
04-27-2004 03:20:58
 Re: Re: Re: Radiator off M with WFE in reply to r4etired, 04-26-2004 18:54:09
r4etired, I might be wrong but I think those bolts (studs) screw into the bottom of the radiator. I'd sure consider replacing them once I went to all the trouble of removal. Your coment is still valid about leaving enough length to work with. My nickel Dick Davis
