freeze plugs
Huston Lloyd
04-27-2004 06:01:31
how do i get to the freexe plugs on my 140 farmall 1977 31311 rockford i pour water into my radiator and it comes out from the bottom of the bell housing area. I removed the sheet metal plate and cant see the freeze plugs i have several books but none really show where the plugs are nor how to get to them to replace them.
thanks for your help everyone
TC
04-27-2004 06:08:53
 Re: freeze plugs in reply to Huston Lloyd, 04-27-2004 06:01:31
Had the same thing happen on a farmall C. The tractor had to be split in order to get to it.
Daniel
04-27-2004 08:36:07
 Re: Re: freeze plugs in reply to TC, 04-27-2004 06:08:53
The freeze plug is on the upper left of the block (viewed from back). The tractor has to come apart but I can't rememer if the flywheel has to be removed. This would be a good time to check the clutch and pressure plate. The is another plug on the upper right, but it is over the end of the cam. No water leak from that one, only oil.
