Re: Re: Farmall H PTO
Craig
04-27-2004 09:10:48
The old one is the square slot arrangement you refer to. The first time the PTO quit, I pulled out the shaft and found it had already been built up before. The inner piece was in bad shape. I tore apart the tractor and had the inner piece on the tranny shaft built back up, put it back together, and now the inner piece is torn up again. I am using it to run a belly mower, so I'm sure it's loaded up pretty good. After this last encounter, I have already torn the whole tractor apart again, hoping to install the newer design, and make this the last time I have to fix it.
