stupid, where is the coil?
farmallsc
04-27-2004 16:16:37
the coil is right above the distributor, right? (1952 super C)
John *.?-!.* cub owner
04-27-2004 21:19:51
 Re: stupid, where is the coil? in reply to farmallsc, 04-27-2004 16:16:37
If it by chance has a WICO magneto on it, the coil is inside. On this type there is no center post on the distributor cap, only the 4 posts going to the spark plugs.
Tommy H
05-02-2004 10:14:47
 Re: Re: stupid, where is the coil? in reply to John *.?-!.* cub owner, 04-27-2004 21:19:51
Does it run?>
If it doesnt....this is your problem, NO COIL...lol
gene b
04-27-2004 19:59:51
That is where it should be unless someone has moved it as you never know who has been playing around.
jamie
04-27-2004 16:27:05
are you looking for a coil or magneeto? Follow the center wire on the dist. cap and it will lead you to it if its there. Should be close.
