Identifying a Farmall M
Ossie
04-27-2004 19:53:37
I have a Farmall M That says it is a Super M on the decals and I think it iS, BUT the serial number on the block is as follows FBKM 280206 under that is X1
now the serial number on the plat is as follows
FBK 293205X1
Now help me determine if this is a super M or just an M . Yet it has the brakes with the bolt on it but they are the 3 bolt pattern not the 6 bolt ,,, which I understand the early Super M had the 3 bolt brakes as well as it being an option on the M .
Checked the number in 100 years of IH and if would fall in the late 1951 years when the Super M was not made until 1952 I think ???
Your help will be appricated
Ossie
John *.?-!.* cub owner
04-27-2004 21:11:35
 Re: Identifying a Farmall M in reply to Ossie, 04-27-2004 19:53:37
According to Guy Fay's IH Tractor Data Book, the chasis serial for a Super M should start with SM, and the engine with C-264. Though I have heard that sometimes doing changeovers, there would be a mixture of parts from the before and after changeover models.
r4etired
04-28-2004 12:57:39
 Re: Re: Identifying a Farmall M in reply to John *.?-!.* cub owner, 04-27-2004 21:11:35
Look at the letter code on the castings if it is W the casting is 51 If it is X it is a 52
Dave_Id
04-27-2004 21:04:14
The serial number says it all, you have a 1952 M, anybody can slap on a set of stickers that says Super M
