electrical switch for H
Mark W
04-28-2004 10:40:19
is the electrical switch on the H and I-4 the same.I imagine it would be, seeing it uses the same motor. Where are the available ? and about how much? THANKS MARK
r4etired
04-28-2004 12:41:07
 Re: electrical switch for H in reply to Mark W, 04-28-2004 10:40:19
H's with a mag had a 1 terminal ignition switch, with a distributor they had 2 terminals. I don't remember the years but some light switches had a high and low charging rate on the first two clicks on the switch
Dave_Id
04-28-2004 11:05:03
They are the same. I have one of each. I'm not sure which switch you are talking about.. the rotary switch for the lights, or the push-pull on off switch.... dave@grussassoc.com
