IH 239 Diesel
Jimmy
04-28-2004 11:59:47
How many of yall have had a bad experience with a 239 crank breaking? I've heard that this is not uncommon. It has happened to us. What is a good substitute for a 239 engine. Perkins? Continental?
ih_bug
04-29-2004 06:45:34
 Re: IH 239 Diesel in reply to Jimmy, 04-28-2004 11:59:47
brand new crank should be around $1400 canadian have sold a couple to a construction guy around here . he didnt bother putting new bearings on the first new crank? the turbo motor takes the same crank may be listed separate in the book.
Tom
04-29-2004 04:28:21
i might have a new crank for the 239, email me tom
Jim
04-28-2004 18:21:56
I work at a IH construction dealer - I have not seen one break. You do have to watch if the crank has been turned as they had different wys of hardning the crank - depending on how it was hardned and how much it is turned it may need rehardning.
JB
04-28-2004 17:12:36
Hi Jimmy, my brother has a 684D with a German D239 and has over 6500 hrs without a problem but did have a broken ring on piston when it was still under waranty.
Uses for baling, plowing, disking and on a NH forage harvester, so it is not pampered. Nieghbor also had a 684D and no problem.
Maybe Bernard le Mecano will comment as there were thousands of 684Ds and 674Ds in Canada.
My 2 cents
JB
Jimmy
04-30-2004 16:27:09
 Re: Re: IH 239 Diesel in reply to JB, 04-28-2004 17:12:36
Thanks guys for the info. Hope you all are doing well
JLE
04-28-2004 13:27:44
I've worked on eguipment for many years that used the D239 & DT239 and I didn't that crank breakage was a problem. I fact I've never seen one, (dozers, loaders, ag tractors backhoe loaders) I've put two in, but from being past grinding to an under size. Jim
Wardner
04-28-2004 13:10:23
I have a busted crank in a C-264 F400 parts tractor. I thought those cranks were industrutable.
Dr. Evil
04-29-2004 07:26:16
 Re: Re: IH 239 Diesel in reply to Wardner, 04-28-2004 13:10:23
Thats only the SECOND Crank from an M,SM,400,450 gas tractor I've ever heard of breaking. And I've been around a LOT of letter & early number series FARMALLS. "Never say Never" I guess.
Jimmy
04-28-2004 13:39:53
This 239 was in a 260A backhoe and tore up. Was wondering if parts were still available for it.
JLE
04-29-2004 03:49:13
 Re: Re: Re: IH 239 Diesel in reply to Jimmy, 04-28-2004 13:39:53
Yes, parts are still available, if you need more info e-mail me. Jim
