Do all A's do this?????
Farmallkid
04-28-2004 13:53:58
We have got an A, When we tried to start it last fall; The first time in about 6 or 7 years, I drove it around for 5 min or so, Then it started steaming out the top of the rad quite a bit. Do all A's do this? One guy told me they do that cause they dont have a water pump on them, dont know if its true or not. Or is the timing out, dont know much about that either. Thanks for any help!
CNKS
04-28-2004 14:17:51
 Re: Do all A's do this????? in reply to Farmallkid, 04-28-2004 13:53:58
No they don't, lack of water pump has nothing to do with it. You either have a clogged system, or you are low on coolant, or your fan belt is loose. If the timing was far enough off that it would overheat in 5 minutes with no load, it wouldn't even start.
Farmallkid
04-28-2004 16:35:29
 Re: Re: Do all A's do this????? in reply to CNKS, 04-28-2004 14:17:51
Hi, The coolant is old, so the rad probably has to be flushed out, the belt is tight, and the coolant is up. Dont have to worry about it steamin now, we made matters worse today, ill post about it.
