M rear end oil
John
04-28-2004 18:32:04
Just wondering what the best rear end oil is to run in my 1950 M? Thanks
Jim
04-29-2004 18:25:13
 Re: M rear end oil in reply to John, 04-28-2004 18:32:04
Why not use the 85W140? Seems like a fair compromise. At our local farm supply store it is the same price as strait 80W or 140W. I think I have the numbers right but I do know there is a multi-grade gear lube reasonable.
randy hall
04-28-2004 20:38:35
i use 140# gear oil in our m tractors. these tractors are over fifty years old with a little wear on all of the moving parts and it doesn't leak as easy. the only drawback is if you live where it gets below zero in the winter it will shift a little harder.
Don L C
04-28-2004 18:56:22
Gear lube 80w -- 90w will do very well.You can get it at Tractor Supply in 5 gal. pails..
