F-20 clutch houseing removel
Paul G. in Mn
04-28-2004 18:47:19
Is there any tricks to removeing the clutch and bell houseing on an F-20? I have one that has electric start but has a hole in the block and want to mount it to anther motor.
John in NE
04-28-2004 22:45:17
 Re: F-20 clutch houseing removel in reply to Paul G. in Mn, 04-28-2004 18:47:19
I went through this last winter on a '36 F20 I'm working on for a friend. It's tough but do able.I rented a three legged puller from a rental store.They called it an axle puller.Bolt the puller to the flywheel and pull like mad.The one I rented had a Tee handle that you acually beat around with a hammer.It worked great,the biggest problem I had was putting it back together.I had to pull the motor out of the frame and I built a stand so the crankshaft sat vertically to the floor.There is not alot of room to get the flywheel back into the bell housing and get everything lined up.You will need a big hammer and several blocks of wood to get it back together.I got pretty rough with it,and didn't seem to hurt anything.I felt like I had really accomplished something when I was done.John.
John in NE
04-28-2004 22:52:00
 Re: Re: F-20 clutch houseing removel in reply to John in NE, 04-28-2004 22:45:17
Now that I,ve read the whole question,here is some more information.After you remove the clutch and flywheel there are about six(?) bolts holding the bell housing to the block.Believe me,removing the flywheel is the biggest part of this project.John.
F20 in Mi
04-29-2004 08:20:52
 Re: Re: Re: F-20 clutch houseing removel in reply to John in NE, 04-28-2004 22:52:00
To reinstall the flywheel, pull our your charcoal grill and let the flywheel heat for about a half hour. Screw a couple of bolts into the flywheel to make handling easier. Put the sleeve in the freezer overnight. You need one guys for the sleeve and two for the flywheel. No beating required. Just slide everything together. Believe me it worked great and we didn't have to worry about damage to the crank etc. Also suggest you replace the throw out beating while you are there.
