10 speed m farmall
RON D
04-28-2004 20:22:36
Just bought a M has a cable that goes into bell housing by hyd. fill. Increases all 5 speeds plus PTO . What make is it. thanks RON
r4etired
04-29-2004 17:54:47
 Re: 10 speed m farmall in reply to RON D, 04-28-2004 20:22:36
Never saw a 10 speed most are 9 speed 5th gear does'nt change. Heisler made one Behlen made on I think they used the cable.M&W also made one. If I remember correctly M&W used an external shaft shift on the left side of tractor. Heisler was on the right
jed
04-29-2004 11:26:43
Now you can be geared like a SM on the high side or a regular M on the low side.
r4etired
04-29-2004 18:00:40
 Re: Re: 10 speed m farmall in reply to jed, 04-29-2004 11:26:43
As far as speeds you will find 1st over is faster than 4th in a super. Our local farmers put them for rotary hoeing and having a gear between 4th and 5th for hauling wagons
Will Sick
04-28-2004 21:19:32
It won't increase 5th.5th is straight thru. It's probably good that it doesn't or you would have one fast road gear.
Farmer Bob
04-28-2004 21:04:24
More than likey it is an M&W overdrive. The Heisler brand was lever activated.
