UGH! Nasty Job
Allan
04-29-2004 04:37:47
third party image
Mornin' All,
I've got to switch these bad boys side to side as the wheels are now dished in.
The local tire shop tells me that the fluid alone weighs 1,113 lbs. I guess it is time for a lot of blocking and time for the old loader to earn it's keep.
I think I'm gettin' too old for this stuff...
Allan
Hagan
04-29-2004 17:48:01
 Re: UGH! Nasty Job in reply to Allan, 04-29-2004 04:37:47
I changed my 1086's ond day and the way I did it was I took the rim loose from the wheel and laid it in aginst the cab. Then I took the cherrypicker and a chain and removed the wheel and took it off-turned it around-reistalled it and then put the rim back on. A lot more SCREWING bolts but a lot safer as you have one rear on the ground at all times.
Allan
04-29-2004 19:18:30
 Re: Re: UGH! Nasty Job in reply to Hagan, 04-29-2004 17:48:01
Hagan,
WOW!! Boy do I like that one.....
Been fightin' with myself all day over this.
I've changed a lot of tractor tires, but I never ran fluid in most of them on account of ground compaction. When the tire co. told me how much that fluid weighed, it kinda throws a different light on my ambition. :>)
Thanks, that really makes good sense, leavin' that tire on the ground (both of 'em, really). This has got to be why you make the big bucks. :>)
Allan
Jonathan Mirgon
04-29-2004 09:19:02
Be Carefull ! Thats enough weight to crush some body. Looks like a job for twenty men and a boy ! You may consider hiring that one done.
Either way good luck !
JT
04-29-2004 08:23:13
I would suggest having the tire shop drain the fluid out, make your wheel changes, and have the fluid put back in. May cost a little but will be far cheaper than the doctors bills 8-))
Or if you don't need it see if they will take it. Around here they have more than they need.
jm2cw
JT
Bud
04-29-2004 06:36:45
Allan
Your right about the fun but I'm more concerned about your Safety. Sometimes it makes sense to pay someone to do jobs like that. Man that is a lot of weight. Please be careful.
Bud
scotty
04-29-2004 04:56:28
Allan, I wish I had a garage like that, I would buy another three tractors to keep the first three happy!!!
scotty
Allan
04-29-2004 05:20:24
 Re: Re: UGH! Nasty Job in reply to scotty, 04-29-2004 04:56:28
Scotty,
Thanks for the kind words, but that setup doesn't belong to me.
The picture was taken before I bought the tractor from a man in Iowa; but, your're right, he's got quite a nice layout.
I'll be working on this 'ole gal out here in the gravel...
I'm trying to talk myself into just moving the rim over to the other ridge and switching the lugs end for end. Either way, it's not gonna be fun.
Later,
Allan
scotty
04-29-2004 06:36:23
 Re: Re: Re: UGH! Nasty Job in reply to Allan, 04-29-2004 05:20:24
Allan, I bought my first tractor with FEL about 6 months ago and am trying to figure out how I managed without one for so long! Good luck on the rears and get some help before you start!
scotty
