340 Farmall hyd problem
PUTTER
04-29-2004 07:04:42
I recently changed the filter and fluid on my 340. After doing this the pump, which is the 9gpm one mounted in front of the dist, won't pick up its' prime. I've tried cracking the line on the output side but no go. It pushes out a little oil but not much. Is there a way to prime this pump or do I have some other problem. I've followed the manuel to the letter. Thanks in advance for any help. PUTTER
Farmall43
04-29-2004 09:16:57
 Re: 340 Farmall hyd problem in reply to PUTTER, 04-29-2004 07:04:42
We have that problem on our 450. I usually just take the air compressor with the air wand and a shop rag to help seal the hole and create a positive pressure in the tank. Make sure the hose is cracked on the output side of the pump. You do not need a whole lotta pressure to prime the pump usually. Hope this helps and good luck.
PUTTER
05-02-2004 05:36:26
 Re: Re: 340 Farmall hyd problem in reply to Farmall43, 04-29-2004 09:16:57
Farmall 43 Thanks for the tip. I'll try that when I get back out to the home place. Thanks again PUTTER
