Super A hydraulics??
Ron/PA
04-30-2004 09:11:02
third party image
I've developed a steady drip out of the lower bolt on this hydraulic connection. Can anyone tell me if there is a gasket in this block, or "O" rings? I've been through the IT manual, and can't find a blow up of this connection. How about pressure? How much if any am I looking at?
Thanx
Ron
Daniel
04-30-2004 09:46:23
 Re: Super A hydraulics?? in reply to Ron/PA, 04-30-2004 09:11:02
There are two o-rings, one for each tube. I would open the fill port on the hydro. block (left side near top) to let any pressure escape. You can get a kit from Case/IH with the o-rings and seal for the pump drive shaft for around 20 bucks with instructions for rebuilding the pump while your in there. When that seal fails it dumps the hyro fluid into the crankcase.
