Farmall H Pulley assembly removal
Bert
04-30-2004 15:54:53
I wanted to remove a pulley assembly from Farmall H to make more room to put on a propane tank. Does a gear come out with the assembly and could I put on a flat plate to cover the hole? Any help greatly appreciated.
49 Cubber!
04-30-2004 15:56:56
 Re: Farmall H Pulley assembly removal in reply to Bert, 04-30-2004 15:54:53
yes,you can put a plate on there.I made one at work today!When you pull the belt pulley assembly,the gear will come out with it.
Bert
04-30-2004 16:04:31
 Re: Re: Farmall H Pulley assembly removal in reply to 49 Cubber!, 04-30-2004 15:56:56
Wow! Thanks for the prompt reply!!!
CNKS
04-30-2004 19:15:03
 Re: Re: Re: Farmall H Pulley assembly removal in reply to Bert, 04-30-2004 16:04:31
You will have to make your own gasket, or use sealer as suggested above, as the gasket is no longer available.
49 Cubber!
05-01-2004 04:36:09
 Re: Re: Re: Re: Farmall H Pulley assembly removal in reply to CNKS, 04-30-2004 19:15:03
CNKS,are you sure,I got one the other day and it had to be ordered,I used it to make my plate.
riverbend
05-02-2004 20:01:18
 Re: Re: Re: Re: Re: Re: Farmall H Pulley assembly in reply to CNKS, 05-01-2004 09:26:47
My dealer had two alternative sources for NOS obsolete parts. One was the dealer network and the other was some outfit that had bought up a bunch of parts( I think). Sounds like your partsman might be too new.
49 Cubber!
05-01-2004 10:36:44
Istill have the box,its has two tags,ones has CNH original parts 01 of 1342401C1 APN:Gasket Blah blkah blah..... ....Second one has BIN DW39A part #1342401C1 Line#3 PSO nuber 7231895 Dealer 617744A OT 2 below all of that it had in big bold C5380 83.There was no warehouse info of any kind on it but on the gasket it self it had TW2004-04.Im sure I could get my dealer to send you one,email if you would like to know their number and location.
CNKS
05-01-2004 12:40:26
 Re: Re: Re: Re: Re: Re: Re: Farmall H Pulley assem in reply to 49 Cubber!, 05-01-2004 10:36:44
Just curious, I like to use gaskets when possible. For the belt pulley, I just used some permatex stuff sealer, no leaks yet. By the way, don't ever forget to put the plug in the rear back in like I did, thought it was my gasket, but oil flows pretty good through a half inch hole. Simply forgot that the plug was rotten and did not replace it, until I wondered where the puddle was coming from.
