Farmall H rear lights
Chris
05-03-2004 04:33:07
I have seen two styles of rear combo lights for the H and M tractors. One looks like the headlights with the red light internal and the other less common one has a seperate red light mounted on top of the work light. Does anyone know which light should be on my 1945 H ? Is the two light type rare as it seems to bring more money? Thanks in advance for your help!
CNKS
05-03-2004 07:07:52
 Re: Farmall H rear lights in reply to Chris, 05-03-2004 04:33:07
The lights you mention were options, I don't know the year they became available, and I have never seen either. You can do what you want, but unless you are actually going to use the red light, I would save some money and put the usual headlight style on.
randy hall
05-03-2004 06:47:50
on your '45 tractor the rear light should be the same as the headlights with no red light at all.
