SUPER M SLEEVE REMOVABLE
FREDDIE WILLIAM
05-03-2004 18:10:13
I NEED KNOW HOW TO REMOVE THE SLEEVES OUT OF THE BLOCK OF A SUPER M FARMALL.ALSO HOW TO PUT THE NEW SLEEVES IN. WHAT TOOL AND WHAT WILL I NEED TO USE
Eric W
05-03-2004 21:14:12
 Re: SUPER M SLEEVE REMOVABLE in reply to FREDDIE WILLIAMS, 05-03-2004 18:10:13
Find a friend who has a sleeve puller. That's the easiest way. Put the new sleeve in the freezer over night and it will drop right in.
Jonathan Mirgon
05-04-2004 03:16:36
 Re: Re: SUPER M SLEEVE REMOVABLE in reply to Eric W, 05-03-2004 21:14:12
You will have to obtain or make a sleeve puller, get a piece of solid 7/8" steel and have it turned round on a lathe the same diameter as the bottom of the sleeve, drill a hole in the puck and then use a piece of heavy duty all thread, and use a nut on the top and a bridge. tightening the nut on the top will pull the liner out. Use a cylinder hone in the bore after all of the sleeves are out to clean them up. then freeze the new liners over night and they will go back in pretty easy.
