Shredder used on Farmall C?
Faber McMullen
05-03-2004 20:15:54
I recently restored a Farmall Super C. I'd like to get a shredder to put behind it, but I'm not sure of what kind it used.
In addition, I'm not sure how to use the little belt pully powered by the PTO lever. It seems to small to use with a belt (only about 2" diameter).
Any insight ya'll could give would be appreciated.
Faber
Navasota, TExas
Deamer
05-03-2004 22:00:16
 Re: Shredder used on Farmall C? in reply to Faber McMullen, 05-03-2004 20:15:54
Hello, I have a model 200 with the same setup...I believe you may have only the pully mounting bolt and a sleeve installed and not the pully. When I bought my tractor, that is how I received it. The pully was not mounted, and of course the belt was folded neatly and packaged with the pully. Good luck.
Deamer
05-03-2004 22:03:27
 Re: Re: Shredder used on Farmall C? in reply to Deamer, 05-03-2004 22:00:16
Forgot to add this. Dave_ID is correct in that the pully is closer to 5 1/2" and not 2".
Dave_Id
05-03-2004 20:31:58
You must be missing something... like the pulley... they are closer to 5 1/2 inches, not 2
Faber McMullen
05-04-2004 04:17:07
 Re: Re: Shredder used on Farmall C? in reply to Dave_Id, 05-03-2004 20:31:58
Where can you buy the pulley's assemblies to go on the small shaft?
D.C. Arnold
05-04-2004 04:50:40
 Re: Re: Re: Shredder used on Farmall C? in reply to Faber McMullen, 05-04-2004 04:17:07
I used a 5' heavy duty shredder on my S/C for some years until I got my 340U.
I have a complete unit with the belt pulley. I removed it when I added the upper lift point to enable me to use 2 or 3 point equipment.
Would sell it all for a fair(?) offer. Think I live not so far from you, in Naples, TX.
Can email or call at: 903-835-1929.
D.C.
