How to Identify a TA unit
Michael Esch
05-04-2004 09:54:54
I just bought several older IH tractors and need some info.
How can you tell if one of these has the TA ?
I have an A that I am sure does not, a Super M, an LP 450 with a single front tire, and a W4.
Thanks in advance for any info on these, by the way what was a W-4 designed for anyways ?
Russ
05-04-2004 11:18:08
 Re: How to Identify a TA unit in reply to Michael Esch, 05-04-2004 09:54:54
THE POSSE;
A 113CID GAS 4F-1R 16.1HP 2014LBS
W4 152CID GAS 5F-1R 30.8HP 3816LBS
M SUP 264CID GAS 5F-1R 44 HP 5140LBS
450 281CID LP 10F-2R 56.7HP 6000LBS
THE FARMALL 45O WAS STD. WITH A TA (TORQUE AMPLIFIER. NICE FEATURE IN THE PULL DEPT.
ALL HP RATINGS ABOVE ARE PTO. TA DROPS THE FORWARD SPEED DOWN ABOUT 33% IN EACH GEAR.
YOU HAVE A GOOD POSSE. RUN THEM PROUD.
Dave_Id
05-04-2004 10:34:06
You need to get some manuals for your machines and learn all about them
Farmallkid
05-04-2004 10:09:27
The ta is a handle on the left side of the seat. The 450 you got should have one. I wish i had a MTA. The W-4 is a standard tread version of the H, H- W-4 M W-6 Then the W-9. These were used in the praires. Then the supers, SM-SW-6. They didnt come out with a s4 or s9. Hope this helps a little. other guys know the hp and stuff like that.
randy hall
05-04-2004 10:29:41
 Re: Re: How to Identify a TA unit in reply to Farmallkid, 05-04-2004 10:09:27
yes there were super w4's and super w9's
Farmallkid
05-04-2004 10:52:47
 Re: Re: Re: How to Identify a TA unit in reply to randy hall, 05-04-2004 10:29:41
O, i have never seen a s4 or s9. have any pics?
Red Dave
05-04-2004 10:01:42
Of that list, only the 450 could have TA. It was an option though, so you'll have to look at your particular tractor.
A W4 is the "wheatland" or standard version of the Farmall H.
