IH 986 clutch help
Cody Spencer
05-04-2004 17:31:42
we have a international 986 that we have to put a clutch in. we decided we'd do it our self and we never put one in on a tractor that size. i was wondering there is any thing i should watch for and tricks in doing this. we are getting the flywheel ground we do that everytime we change a clutch. all help is appreciated, thanks. Sincerely, Cody Spencer
Aces
05-05-2004 05:12:55
 Re: IH 986 clutch help in reply to Cody Spencer, 05-04-2004 17:31:42
Cody make sure you have good stans to hold the tractor, use a guide screwed into a bolt hole of the TA housing on both sides to help guide back together. When you go back together bush the fingers down on the pressure plate and put a block under the back of the fingers to hold them down, put the pressure plate on the PTO drive shaft and the clutch drive member on the TA input shaft. Put the tractor back together and then bolt the pressure plate to the flywheel. This way the splines are lined up and the only thing left is the pilot bearing, if you put the clutch on the fly wheel then put the tractor back together you could push the TA in put shaft back into the TA then you will have to do a TA job. You can get at the clutch from the inspection hole below the clutch housing, make sure you get the blocks out after wards.
cody spencer
05-05-2004 08:35:51
 Re: Re: IH 986 clutch help in reply to Aces, 05-05-2004 05:12:55
we have a alinment tool we use for putting it back together it is worth the money. it saves a lot of time. we used it on our IH 674 when we put the clutch in that this spring.
