F-12 motor with a dipstick?
Mike
05-04-2004 20:09:02
I have had about 13 f-12 and 14 over the past 5 years and never seen one with a dipstick to check oil Have any one seen this befor is this motor out of somthing else? oil pan does not even have the check plugs. thanks Mike
Zak
05-05-2004 11:10:37
 Re: F-12 motor with a dipstick? in reply to Mike, 05-04-2004 20:09:02
I had a 1934 gasoline F-12 and it had a dipstick. The funny thing is, I have a 1955 300 gasoline rowcrop, and it has the petcocks and NO dipstick? Doesn't make sense to me, but I'm sure some accountant somewhere thought of a good reason to go with petcocks and not a dipstick. -Z-
Dan in Ore
05-05-2004 02:58:22
The gasoline models had dipsticks. The try-cocks were there not only to check the oil level, but also to drain off the excess distillate that slipped past the rings. Distillate was a very inefficient fuel but it was much cheaper than gasoline.
pg
05-05-2004 02:44:42
i have 2 very early w12 tractors [both 1934s], and both have dipsticks. oil pans have no drain cocks. think only the early models had them. pg
pg
05-05-2004 17:30:26
 Re: Re: F-12 motor with a dipstick? in reply to pg, 05-05-2004 02:44:42
mine are both mccormick-deering.
plowpusher
05-04-2004 21:16:31
Mike, recently sold a an f-12 power unit with a dip stick, it had a had a hand clutch with a right angle belt pulley. oil pan did not have the oil level plugs. The radiator had "INTERNATIONAL" cast into it... GT
