300 Utility 1958 Model
Larry Torr
05-05-2004 04:26:58
Hydraulic oil is migrating into the crankcase,I'm suspecting the pump or the hydraulic valve (threeway). Has anyone experience this, and where to begin, THANKS!!
SIMO IN OHIO
05-06-2004 00:07:02
 Re: 300 Utility 1958 Model in reply to Larry Torr, 05-05-2004 04:26:58
HOPEFULLY IT IS JUST THE PUMP SEAL. IT ALSO COULD BE THAT YOUR PRESSURE RELIEF VALVE IS DIRTY OR MALFUNCTIONING AND NOT UNLOADING THE PUMP, THUS BLOWING SEALS. BEEN HERE DONE THAT AND FILLED THE CRANKCASE. GOOD LUCK.
SIMO.
Gus
05-05-2004 18:08:31
I had the same problem. My pump was tired so I had it rebuilt with new seals etc. That was at least 10 years ago and it's still working great. Gus
Aces
05-05-2004 04:57:57
Larry it would have to be the pump seal.
