Carb Parts for IH 2544 Tractor
Marvin S
05-05-2004 15:42:07
I have a International I2544 model tractor with what I think is the c-200 gas engine.I am in need of a carb kit or at least the gaskets and a fuel shut off solinoid, it goes in the bottom of the bowl like where the main jet would go.Is it possible to just delete this thing? Or does it actually meter the fuel?This looks like it is the IHC brand carb PN406 804 R91 1 1/4 updraft carb.I called the industrial IH dealer and he said the kit number is 387459r-92 or r-91 but it is obselete. The fuel shutoff # is 71425c91 also obselete.Nobody really wants to deal with me because it is an industrial tractor.Engine #200ct24020521 chassis #2320472u016689. Thanks for any help.
Kent
05-05-2004 20:37:01
 Re: Carb Parts for IH 2544 Tractor in reply to Marvin S, 05-05-2004 15:42:07
Marvin, I am in the same boat, I have a 2544. The tractor is a 544 with a supposed heavier front axle. Your carb should have a tag or numbers that your local NAPA can run and get you a kit. Mine took part # 2-1555 list $41.13, I got it for $28.49. Th kit is a pretty good kit. The fuel shut off is to keep the tractor from running on after the key is switched off. Mine dont have it, I have a manual tranny without a TA. It seem the fuel shut off is more common with hydrostatic tranny. Check with NAPA. I just got my block and new pistons,etc back from the machine shop, doing a complete over haul. Good Luck, Kent
Marvin s
05-06-2004 04:19:58
 Re: Re: Carb Parts for IH 2544 Tractor in reply to Kent, 05-05-2004 20:37:01
Mine is the hydrostat model.Is youre carb the IH one if so I will try to use youre part number to get a kit. Thanks
Kent
05-06-2004 19:35:22
 Re: Re: Re: Carb Parts for IH 2544 Tractor in reply to Marvin s, 05-06-2004 04:19:58
Th Napa man seemed to think mine is the Marvel/Schebler. My manual says for a 2544 with Hydro takes a IH carb #406804R91 and a Gasket package # 387454R92 and a overhaul package # 387459R92, these are all IH part numbers. I would take the whole carb into the Napa and let him match you up a kit. Good Luck, Kent
Marvin S
05-06-2004 20:00:04
 Re: Re: Re: Re: Carb Parts for IH 2544 Tractor in reply to Kent, 05-06-2004 19:35:22
Thats the problem since mine is the IH carb. All of the part numbers that you have are the same ones Ive got and they are obselete.
Kent
05-06-2004 20:32:19
 Re: Re: Re: Re: Re: Carb Parts for IH 2544 Tractor in reply to Marvin S, 05-06-2004 20:00:04
Marvin, All the more reason to visit the man in the Big Gold Hat!! He has a carb book and can get practically anything. Take the whole carb and he can match it up. Kent
