B Farmall cutting out
Mark B
05-05-2004 17:30:45
I have a B that I mow with. The last time I mowed with it(about a couple of weeks ago) I ran it out of Gas. I added gas and now has a bad miss at high idle sort of like a bad spark plug. I cleaned all plugs, checked fuel flow to carb but is still not running right. Any suggestions would be appreciated. Thanks, Mark
Mark B
05-07-2004 19:19:28
 Re: B Farmall cutting out in reply to Mark B, 05-05-2004 17:30:45
I will try to take the carb apart this weekend.Thanks for your advice I will let you know how it turned out. Mark
parts man
05-05-2004 17:47:01
Mark, since the problem started after you ran out of gas, I'd guess that some dirt got into the carb and is blocking one of the small passages. Take it apart and give it a good cleaning.
