39' M with oil dipstick
Paul G. in Mn
05-05-2004 18:29:04
My 39' M has a dipstick to check the oil but also has the petcocks in the oil pan. This is a disolete tractor from the factory, would this be right to have a dipstick? I did look up the numbers and they seem to be right for this tractor.
NDS
05-06-2004 04:53:57
 Re: 39' M with oil dipstick in reply to Paul G. in Mn, 05-05-2004 18:29:04
If it has boss on left side of engine for fuel pump that is covered with plate it is probaly U6 combine or stationary engine or factory replacement block. If not it has probaly been drilled for dipstick.
randy hall
05-05-2004 20:29:51
all m blocks are cast with the place for a dipstick, the power unit engines had the dipstick installed from the factory and if the block was factory remanufactured it was drilled and a expantion plug put it the hole.
CNKS
05-05-2004 18:58:06
The previous owner could have had it drilled for a dipstick, many had the raised place on the block that was drilled for the later engines, but I don't know when IH started doing that. I once saw a 1952 M with a dipstick, I imagine it was drilled.
Zim
05-05-2004 19:53:13
 Re: Re: 39' M with oil dipstick in reply to CNKS, 05-05-2004 18:58:06
I'll bet someone had it drilled. Grandpa had our H block drilled for a dipstick, then cut a dipstick to fit and made a "full" line. A bit handier than the high-low petcocks.
Allan
05-05-2004 18:31:56
Paul,
I would guess that the block has been swapped out within the past few years.
Allan
Paul G. in Mn
05-05-2004 18:34:44
 Re: Re: 39' M with oil dipstick in reply to Allan, 05-05-2004 18:31:56
It is an M block though, C-248
