H and 350 transmission bearing interchange
Gary
05-06-2004 05:14:02
Will transmission parts from a RC 350 work in an H?
Wardner
05-06-2004 15:22:07
 Re: H and 350 transmission bearing interchange in reply to Gary, 05-06-2004 05:14:02
Seeing as no one has answered I'll take a stab at this.
The countershaft is different because it is hollow. The clutch gear (sometimes called input) is different because of the TA. Don't know about the main shaft. Some of the gear ratios are different. I am guessing that some of the bearings might interchange. It is hard to figure out interchangebility because the later tractors used a different part # system. A salvage yard operator would know. Call Mike Bunck at 785 548 7437.
