more on hard starting 1066
Tom
05-06-2004 22:38:15
Thanks for the replies, I put new wires and battery terminals and put the battery charger on , it will turn over alot faster now but still had to turn over for a long time to start. I pumped the hand fuel pump a few times and it started immediately. I tried this several times throughout the day and each time started when I did this but wouldn't if I didnt. I guess it wouldn't be to hard to do this every time I started it but any ideas what is causing this? Thanks
RAS
05-07-2004 08:06:23
 Re: more on hard starting 1066 in reply to Tom, 05-06-2004 22:38:15
Tom just a question. When you bring it down from rated speed to idle does it die?
Hugh MacKay
05-08-2004 02:08:43
 Re: Re: more on hard starting 1066 in reply to RAS, 05-07-2004 08:06:23
RAS: Now your getting into serious problems, don't scare him too badly. I know what your thinking and you may well be right.
RAS
05-10-2004 09:27:27
 Re: Re: Re: more on hard starting 1066 in reply to Hugh MacKay, 05-08-2004 02:08:43
Well you know if it dies when you come from high to low idle it's time for a fuel injeciton pump.
Hugh MacKay
05-10-2004 15:30:02
 Re: Re: Re: Re: more on hard starting 1066 in reply to RAS, 05-10-2004 09:27:27
RAS: Oh that feeling when the tach hits zero and takes the bottom out of your wallet with it.
Novel Idea Guy
05-07-2004 06:46:58
I agree. You've got an air leak, and you're losing prime on the pump.
Hugh MacKay
05-07-2004 02:04:20
Tom: Sounds as though the fuel injection system is taking in air. You must have a leak somewhere in system. It could be anywhere between fuel tank and injection pump or even within the pump. If the tractor is working well when running, then air must enter during time engine not running. Or you have a leak that could get a whole lot worse. Look for cracked lines, cracked filter base, bad seal on filter. Had a Cat once performance was terrible, after some looking we discovered gasket behind inspection plate for timing was leaking. Not enough to allow fuel out but did let air in.
scotc
05-11-2004 07:50:06
 Re: Re: more on hard starting 1066 in reply to Hugh MacKay, 05-07-2004 02:04:20
i'd start with the filters, maybe too tight and doing in the gasket, or the base could have old gasket stuck to it, are the bleeders tight?
