560 LP Head
Ohio M Puller
05-07-2004 05:52:09
Just wondering if there is any difference in the 560 LP and 560 Gas heads, wondering if the LP head would bust compression numbers?
Ohio M Puller
Heat Houser
05-07-2004 21:41:51
 Re: 560 LP Head in reply to Ohio M Puller, 05-07-2004 05:52:09
LP heads had Stellite exhaust seats and Stellite valves. These would take the abuse better since LP did not have any lead in it. An LP head will work fine on a gasser since the difference in compression, higher on the LP, was done by a raised step on the top of the piston. As I recall, the gasser piston was flat not stepped like the LP. I am running LP pistons in my 560 gasser to bump up the compression. It tends to diesel when shutting down hot.
Jim J
05-07-2004 07:17:13
The 560 gas and LP heads are the same.
