Farmall M live hydraulic Reservoir
Jack
05-07-2004 08:29:51
I am adding M&W live pump. If I use the Liftall pump as a reservoir can I keep it in operation? I realize each hydraulic system couldn't be used at the same time due to fluid capacity. Is this the only problem? I want to use the live pump for a three point and the liftall for remotes.
CNKS
05-07-2004 17:45:26
 Re: Farmall M live hydraulic Reservoir in reply to Jack, 05-07-2004 08:29:51
I don't know, but you can get a two lever spool valve and do the same thing with the live pump.
