oil filter and fluids
farmallsc
05-08-2004 15:16:22
1951 super C set inside for 18 years ran today
1. where can i get oil filter/seal
2. what kind of fluid does touch control use will regular hydraulic fluid work?
3. the andtifreeze in my radiator is good color, is my radiator ok?
why im draining all the liquids and replacing filters are there any others i should replace?
Dave_Id
05-08-2004 15:52:53
 Re: oil filter and fluids in reply to farmallsc, 05-08-2004 15:16:22
Most mfg's of filters send the seal with it. I use Fleetguard from the IH dealer. YOu can get HyTrans hydraulic fluid from IH also, you can use a generic hydraulic fluid, but make sure it is made to IH specs. Only thing green antifreeze tells you is that it has anti freeze in it. If it's been 18 years since it was changed, I assure you it needs changing. The radiator more than likely is in good shape, but youll just have to watch the temp gauge for awhile to make sure it doesn't overheat.
