B Farmall Fan Bolt
Mike
05-08-2004 15:17:22
I have a question concerning the fan hub on my B. Is there supposed to be a flat washer under the nut on the back of the hub? Or does a nut fit in the milled out slot without any washer? Mine had a thin lockwasher in front of the nut. I do not see how this would work. Help....Thanks
Red Dave
05-08-2004 15:40:32
 Re: B Farmall Fan Bolt in reply to Mike, 05-08-2004 15:17:22
No, there's no washer under that nut. The nut fits into the groove on the engine side of the mount. You don't turn the nut, turn the shaft with the hex part behind the pulley, the nut stays still.
Mike
05-08-2004 17:45:08
 Re: Re: B Farmall Fan Bolt in reply to Red Dave, 05-08-2004 15:40:32
Thanks, That exactly how I fixed it. Mike
