Super A . I want to add a sprayer w/boom
tbird
05-09-2004 03:44:17
Anybody here ever add a rear sprayer with a boom? I use my Super A to cut grass with a woods L59. I have been over run with weeds and clover, would love to buy a sprayer and put down some 2-4-D. I have a neighbor that could weld up a bracket to make it work. just looking for any tips or advise. Thanks
wh - like this ?
05-09-2004 17:38:59
 Re: Super A . I want to add a sprayer w/boom in reply to tbird, 05-09-2004 03:44:17
use electric - this one holds 15 gallons. use it to spray in the garden and have a 5 nozzle boom for yrad. look at picture you will see te 2 nozzle boom on it. they are set at angle to blow into the plant leaves. works great.
CNKS
05-09-2004 12:10:16
I have sprayed with the type sprayer you are talking about for over 30 years, Rollie and Jay have given you good advice. I modified a commercial sprayer for my C and use it to spray my own property with. I built a shield so that I would minimize drift off my own property, due to our constant wind. 2,4-D is one of many herbicides that are not restricted use. Kansas law says you can spray those without a license of any kind on your own property, as long as you follow labeled instructions. If you spray for others you need a license. I imagine your state has a similar law, but check with your county extension agent first. Just don't spray next to your neighbors flowers or tomatoes. For restricted use pesticides, you must have a license, regardless. In Kansas you must pass a fairly simple test and pay a small fee (I think it's less than $100). I spray 2,4-D and glyphosate for my combination of bindweed, sandbur, and puncture vine, as mowing has no effect on those 3 weeds, except to spread the seed around.
Rollie, NEPA
05-09-2004 09:30:11
Third: I just completed a boom sprayer project for my H. I have about $250.00 invested. I used an 8 roller Hypro pto pump, a 55 gal plastic barrel and 80 degree nozzles. I also added a hand operated spray gun w/25ft hose. Everything works well. In Pa you do not need an applicators Lic. to use 2-4-D that I am aware of. If I am not mistaken you may use restricted herbicides as long as someone with a applicators Lic. is supervising and within a certain time/distance from your location.
Maybe some one could expand on this and correct me if I am wrong.
Rollie
Jay
05-09-2004 09:49:54
 Re: Re: Super A . I want to add a sprayer w/boom in reply to Rollie, NEPA, 05-09-2004 09:30:11
I would suggest the option of turning off the booms separately and the ability to fold the booms upwards. Out the back will limit your turning ability when close to stuff. The reason I would suggest putting in valves to close off the booms is so if you want to mow and spray at the same time, as I do, you can. I spray every few weeks in the summer. Generally for mosquito control, but also 2-4-D for the dandelions.
I think the advantages of mowing & spraying together go beyond time savings. For bug spraying, you irritate the little buggers by mowing and zappo with the spray. For weeds, you get a cut that will take it in directly.
Not only that, but if you mow at the same time, you have built in markers!
Good luck - I think this is a worthwhile project. I'm hoping to build a wick-type sprayer this summer. I won't have to worry about drift onto my trees as much then.
CNKS
05-09-2004 17:51:17
 Re: Re: Re: Super A . I want to add a sprayer w/bo in reply to Jay, 05-09-2004 09:49:54
The more leaf area you have the more intake of herbicide (at least up until the time the weeds are too big to kill). You don't want to mow before applying. Less herbicide will be taken in through a cut than an intact leaf.
Hugh MacKay
05-09-2004 15:20:19
Jay: If I applied 2-4-D every few weeks I would never tell, certainly not on the world wide web. Rather than a license you may find yourself with a bounty on your head. You are the kind of guy, commercial farmers are tempted to send two guys in a black Lincoln to deal with you. I had a neighbor used to apply Roundup and let it lie there for weeks, turning brown. What better way to get the public up in arms over chemicals. In 3 days or less the roundup has done it's job. Plow it under. Chemicals are a valuable resource and tool for agriculture. They don't need the kind of publicity people like you and my neighbor give them.
Secondly, 2-4-D is a foliar spray and will work much better on a whole leaf than one damaged by mowing. You clippings will prevent a good portion of chemical from actually reaching plant. It's been 40 years since I studied this but as I recall there is only one stage of growth that 2-4-D will actually kill dandelions. I really have never tried to kill dandelions in a lawn, they are kind of like snow in the Carolinas, they only hang around a short while.
I came from and farmed in a jurisdiction where commercial farmers asked for and thought they achived licensing for all chemical applicators. After accepting our proposal the government went ahead and licensed a complete line of diluted chemicals for garden centers to handle, which didn't require licensing. Really all they did was give the garden supply business a license to charge 2000% markup on active ingrediant.
Jay
05-09-2004 16:24:41
 Re: Re: Re: Re: Super A . I want to add a sprayer in reply to Hugh MacKay, 05-09-2004 15:20:19
No, I said I spray every few weeks, and mostly for mosquitos. I only spray 2-4-D about twice a year.
The only time 2-4-D will actually kill the dandelions is in the fall, shortly before a killing frost. I spray then. I also spray mid-summer for the new ones. While it won't kill them, it will set them back enough that I'm without them for the rest of the summer.
Lastly, if you know any farmers that want to lynch me, or turn me over to the EPA, feel free. My email was available in my first response, as it is in this one. I'm easy to track down. I live in the heart of farm country, and in the country myself. By the way, I'm using Tempo Ultra for pest control. Great stuff.
Hugh MacKay
05-09-2004 19:55:00
 Re: Re: Re: Re: Re: Super A . I want to add a spra in reply to Jay, 05-09-2004 16:24:41
Jay: On a lighter note, on mosquito spraying. In northern Canada in granite rock and peat bog country you would need to be careful spraying mosquitos with a Super A. Some of them are larger than a Super A. A group of farmer friends of mine went sport fishing in this country. What they didn't know was military was conducting some low level flying manuvers in the area. When the planes started buzzing them the boys thought they had drank a bit too much rum. A story circulated of military aircraft pulling baloons, some though it was overweight farmer fishermen being lugged off by huge mosquitos. Personally I have never liked mosquitos well enough to even go there.
Jay
05-09-2004 16:29:03
Forgot 1 thing.
As far as mowing and spraying at the same time - I'm not putting my clippings onto the grass I just cut, it's always into the uncut grass, so, no, the clippings don't smother it.
Also, you get very little leaf cut off the dandelion when you mow, or at least when I do, so most of the spray is still going where it needs to go. What I do get, is the flower cut off, and maybe it's a dumb theory, but I feel a little 2-4-D right down the throat of the beast has to help. I don't know, but it sure works well for me.
Hugh MacKay
05-09-2004 18:47:32
 Re: Re: Re: Re: Re: Re: Super A . I want to add a in reply to Jay, 05-09-2004 16:29:03
Jay: That does present a clearer picture, and yes probably a great time for nailing the mosquito. You also have good point on the dandelion, the closer you mow the flater he can grow.
I really don't know of any farmers that will be out looking for you. I just tend to get a bit upset when I see someone make a statment that might get construed by envoirmentalists as excessive. I used to tell my neighbor with roundup treated field turning brown, get it plowed under. He would say roundup is the most envoirmental friendly chemical herbacide we've ever used. I said yes you and I know that but do all those folks driving by know that. The public love to hate chemicals, we have to be careful not to give them anymore amunition than what they already dream up.
I used to grow some root vegetables, and some of the most dangerous chemicals I ever dealt with were granular handled by dry applicators. A guy about a mile away always made rude comments to me in public every time he saw my sprayer in the field, yet I think I could have loaned the boxes off my dry applicator to him for seats at his family barbecue. He stopped me once to complain, my spray mix was irritating him. I said, " that is funny I'm only spraying 5 lbs of epsom salts in 100 gallons of water." Epsom salts will make tomatoes, green and yellow beans ripen faster. I truly wish I could have sprayed enough epsom salts on him to turn his verbal diarrhea to the other type.
I perhaps get a bit more worked up on these issues than I should. However my home was in Nova Scotia and there we had the largest crop loss in North American history, That is roadside value of the crop. The pest was the spruce budworm. Envoirmentalists said no to chemicals and a lame duck government gave in. The loss, 40 years employment for 25,000 people. We must be very careful not to give people wrong impressions.
Paul in Mich
05-09-2004 20:31:26
 Re: Re: Re: Re: Re: Re: Re: Super A . I want to ad in reply to Hugh MacKay, 05-09-2004 18:47:32
Hugh, The guy you mentioned who complained about your spray irrating him is basically a victim of his own ideology. The Enviromentalists are indeed passionate about their convictions, yet so ignorant of the facts, which place them in situations such as the guy you mentioned. They see a sprayer and this little light bulb automatically goes off in their head that says to them that nothing good could ever come from a sprayer, and so they feel this urge to confront the person using the sprayer regardless of the solution that comes out of it. While Round-up is the most envirnmentally friendly herbicide known to man, it still doesnt satisfy the environmentalists. DDT was banned because of faulty and fraudulant data. Some of these people just arent honest. I notice it with the anti-smoker activists. It isnt good enough for them to have a non smoking section in a restaurant, they try to have smoking banned altogether even though they cant smell a thing. Yet these same people will go to the casino where theres an ashtray at every slit machine, and never complain. Which leads me to believe that it isnt about health nor the environment, but rather its about controling someone elses life. Its about the guy you mentioned thinking he has a right to walk on your land and tell you what to do. Or the guy who has no investment in the restaurant thinking he has the right to tell the one who does have the investment how to run his business even though nobody is forced to do business there and subject himself to the smoke. Its about someone trying to sell a book comming across as an expert thereby pressuring congress to pass a bill banning DDT and self riteously standing by while thousands and millions of people die every year from Malaria, West Nile virus, and other diseases caused by mosquitos, and arrogantly think she saved the world. As you can see, I too get worked up over these so called do gooders who actually mean harm to some of us.
Hugh MacKay
05-10-2004 03:46:48
 Re: Re: Re: Re: Re: Re: Re: Re: Super A . I want t in reply to Paul in Mich, 05-09-2004 20:31:26
Paul: While what you say is very true, there also been a lot of farmers and other users have done some quite bone headed actions that have given the do-gooders amunition. When I was a kid we lived along a gravel bottom river anywhere from 1' to 6' deep on average. Every farmer along that river used to tie his manure spreader to a tree with a long cable, to allow it into deep water, thus cleaning up at end of season. Must have been some fodder for do-gooders.
As a young man I remember our fathers generation, who by the way were some of the first farmers to use commercial chemicals on mass. They tended to be of the opinion if a little worked a lot was better. DDT was one in question, it worked so well on barn flies, that second time out dad drowned them with it.
Then there were the guys that chased atrazine resistant weeds with atrazine. Had one guy tell me of using 13 lbs of 80% to the acre. They killed what would still be the most economical weed control in corn. For 25 years I operated a 7 year rotation of 3 years corn and 4 years alfalfa. The only chemical I ever used was atrazine, and I was getting 100% kill of weeds in corn. My atrazine use was not excessive or I couldn't have grown the alfalfa. In fact I was growing more TDN per acre from alfalfa than corn. For those who don't know TDN is total digestable nutrients. Now I realize that wouldn't work with some of the crop rotations today.
I also realize that no till farmers must allow the roundup treated land to turn brown. In the early days of roundup we were tilling and more common sence could have been used. People will accept new technology if it's not thrust on them too quickly. Farmers sometimes have not been the best public relations personell.
Paul in Mich
05-10-2004 08:23:44
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Super A . I wa in reply to Hugh MacKay, 05-10-2004 03:46:48
Hugh, I agree with you to the extent that we cant hold ourselves or farmers blameless in giving ehe environmentalist wacos plenty of fodder. not unlike a lot of oter people, we get into this mode of "Since some is good, more has to be better" mentality. We've done it with herbisides and pesticides, we've done it with fertilizer, we've done it with Horsepower, and just about everything else in our lives. Heck, we can't even live in the same size house we did 50 yrs ago. If it doesnt have at least 3.000 sq ft, it wont do. I digress. As to the herbisides, fertilizers and pesticides, I believe there should have been a lot more training for the users, and not just advertising info, but real usefull results oriented data. The companies threw it all out there, and left it up to the farmers to figure it all out. All these products are usefull if used properly, but it is also easy to misuse them through ignorance, thereby giving the environmentalists the traction they get. I think the hardest thing for anyone to be able to conceive is that some of these products require only a few ounces per acre to be effective. Our brains dont relate to that idea very well. Its like trying to explain a tenth of a second. However, all this not withstanding, I am apalled by the fact that our legislators act without reliable and accurate data when they succumb to the emotions of a few activists who heap piles of conjecture, false data, unfounded scenerios, and otherwise fraudulant agendas when banning a product. I also agree with you that the average suburbanite wanting to use these products on his lawn and garden has no business using such products without proper education and orientation. I don't know about licensing, but certification is certainly not inappropriate. Even diluted versions of some products available in garden centers can be misused if the user is not properly informed.
CNKS
05-09-2004 18:03:36
Most of the kill is caused by intake through the leaves, not the stem. In general you are correct about the use of 2,4-D as the label says to only use it twice a year on the same area. You are also correct about mowing not touching the leaves on dandelions, unless they are very large. So your way of killing them probably works, but not for the reason you say. If you have other taller weeds, you should wait a couple of days before mowing so that the herbicide translocates to the roots, that's what you have to kill.
Jay
05-10-2004 08:26:56
 Re: Re: Re: Re: Re: Re: Re: Super A . I want to ad in reply to CNKS, 05-09-2004 18:03:36
Like I said, it was only a theory =)
This isn't a pasture, or anything, it's my lawn, a few acres, so it gets mowed often. The dandelions never get tall, but often quite wide. I was never sure if my theory actually did any good, but like I said, it's always given me a good kill without using more than the recommended rate. Besides, I still like the idea of using the uncut grass edge as my markers =)
By the way, if my neighbors would work on controlling their dandelions, maybe eventially I could quit spraying mine! LOL
Have a great day!
CNKS
05-10-2004 09:18:04
 Re: Re: Re: Re: Re: Re: Re: Re: Super A . I want t in reply to Jay, 05-10-2004 08:26:56
Never-ending battle, my yard is clean except for a few around the edges, neighbors on either side are full of them, so I'll have to spray until I die (hopefully not from 2,4-D fumes).
Hugh MacKay
05-09-2004 07:00:16
tbird: Why spend money, just keep on mowing. When its mowed off weeds and clover are just as green as grass. With enough mowing most of the undesirable plant life will disappear anyhow.
Most jurisdictions today require you to have a lisence to own and operate a sprayer as well as for buying the chemicals. That one alone could cost you three times as much as sprayer. Old sprayers are the kind of thing most farmers give away today to avoid liability. Not sure how well that clears them if they give it to someone without a lisence.
tbird
05-11-2004 00:08:30
 Re: Re: Super A . I want to add a sprayer w/boom in reply to Hugh MacKay, 05-09-2004 07:00:16
Hugh I think you might be missing my intent. I have been cutting this about 10 years now and it has been spreading (clover mostly). It's choking my stand of grass. I have been using a small 5 gal.spot sprayer to fight it with good luck. but now I would like to utilize my SA instead of walking all over the large yard . I'm just looking at saving time and tring to get my yard back in top shape. just cutting 1 time a week has not seemed to slow down the weeds. I really spent some time on 1 part of the yard with some turf builder 2 and 2-4d that really looks great. I don't know if you use tb2 but one of its main weed control ingredents is 2-4D. I'm mainly looking at nothing bigger than 25 gal sparyer
Hugh MacKay
05-11-2004 06:11:42
 Re: Re: Re: Super A . I want to add a sprayer w/bo in reply to tbird, 05-11-2004 00:08:30
tbird: I do see where you are coming from, and your desire to have that perfect stand of grass. I can also see the use of chemicals as a tool to achive what you are trying to do.
I am 62 years old and probably sprayed my first chemicals around 1960. In the past 44 years I have sprayed a wide variety of the ag chemicals on the market. I have used chemicals that even minimum exposure of my flesh to the chemical, could be lethal. I was spraying one day and watched my neighbors cat walk across the treated field, the cat didn't make it. A classmate of mine in high school died the victim of cancer. While no one ever pointed a finger, he told me on his death bed, he always had a gut feeling there was a relationship to use of a certain chemical. I have forgotten the exact name of the chemical, but remember at the time it was not a restricted chemical.
At 62 I now wonder if some of the ailments I now suffer from are related to my use of chemicals, or was it tractor fumes, or was it silo gasses, or was it methane and other gasses from livestock, or is it the depletion of oxygen caused from burning fosil fuels, or was it smoking? Who knows, probably a combination of all. I do have a pesticide license which allows me to apply just about any ag chemical going. A number of farmers know this. Can they hire me? The answer is yes if they wish to pay me the going rate for a Corperate Lawyer. If farming would I still use chemicals? Yes it would be a business decission.
From my perspective when it comes to my home and surrounding grounds or as a hobby the answer is NO. Corperate America don't care what these products may be doing to us, all they can read are dollar signs. I hope you can understand where I'm coming from. I certainly hope no one has to suffer ailments I see amoung some of my former farmer colleagues, just because they didn't like clover or dandelions.
