super a clutch problems
Ky Mac
05-09-2004 16:59:01
Need help on my super a, my clutch on my a is not engaging to allow me to shift gears after the tractor is started. I can change gears with the tractor turned off but not while it is running. I tryed adjusting the cluth pedal but no luck.
Hugh MacKay
05-09-2004 19:25:55
 Re: super a clutch problems in reply to Ky Mac, 05-09-2004 16:59:01
Mac: Sounds as though you may have a pilot bushing bad or clutch disc sticking on shaft. Have you tried letting it run for awhile, in gear with clutch in? Slim chance but it may correct it. Probably you will need to split tractor.
