Belt Pully on 48 M
BB
05-09-2004 18:18:31
Does the belt pully housing pull oil from the transmission to lube itself on my 48 M? I looked for a check plug and seen none but there was a plug in the top of the housing. The IT manual had nothing to say about fluid in the housing.
BB
randy hall
05-09-2004 18:21:58
 Re: Belt Pully on 48 M in reply to BB, 05-09-2004 18:18:31
yes it gets it's oil from the rear end. if you just put it on and it has been empty you should pour a quart of gear oil in that pipe plug hole that you found.
