TD-14A International pre-combustion chamber
Kenneth
05-10-2004 06:13:35
I need a set (4) of pre-combustion chambers for a TD-14A. How are the old combustion chambers removed? Will chambers from a TD-20 fit the TD-14
Farmaller
05-10-2004 17:30:22
 Re: TD-14A International pre-combustion chamber in reply to Kenneth, 05-10-2004 06:13:35
There was a special puller made to remove the cups. Most of the time they are so cooked with carbon you have to drive them out through the small injector hole in the head. Webers Tractor Parts might have the new cups.
Jimmy King
05-10-2004 10:10:32
Kenneth if I remember right they should just slide out because the injector holds them place if the hole is carboned up you will need to clean it up.
Kenneth
05-11-2004 05:12:27
 Re: Re: TD-14A International pre-combustion chambe in reply to Jimmy King, 05-10-2004 10:10:32
Thanks to both you, Jimmy and the Farmaller for the information. Now, one more question. I have located a TD-20. From the top the injectors appear to be the same as the TD-14. Do either of you know if they are the same and if so are the pre-combustion chambers the same? The machine has been outside without a hood for several years and there is a lot of rust. I've begun soaking the exterior of the injectors with Sea Foam; but, they may be a tough pull. Your answer may save me a lot of trouble. Thanks Kenneth
